New thread due to losing the old one.
Parts are coming in thick & fast (means money is traveling in the other direction
The project again is a worked 8 valve that Peter Taylor is building up for me. The engine is a DKZ/Mi16 hybrid'y sort of a thing (Peter please correct me if I'm wrong). The block has been machined and a compression ratio of 11.5:1 is what we have decided on. The internals are, and once again please correct me if I'm wrong, Mi16 liners, pistons and rods but retaining the standard crank. To stop oil surge and starvation, one of Peters baffled sumps will be used.
A DKZ head with one of Peter's larger cams, BBM cam wheel and double valve springs. Also after much ummmm'ing and ahhhhh'ing I'm going to see how I go with a Davies Craig electric water pump (water pump wont be driven off the cam belt).
I have a Wolf3D ECU that will be running everything in conjunction with a Davies Craig control unit taking charge all thing water temp related.
I was hoping to be a lot further through this at this point in time but unfortunately I was ran off the road in the middle of last year and incurred some fairly serious suspension damage so I figured it was time for new suspension (quite costly)....
So, know that I have some money saved up again its all systems go (so to speak) so I can get the motor out of Peters hair and down in Melbourne so I can start putting it all together.
Graham is kindly supplying me with a series 1 Mi16 gearbox and flywheel (needed for the ECU) and I'm about to order a Quaife LSD for obvious reasons. Its really just a matter of tidying up all the little bits and pieces now, clutch, ECU loom, oil cooler etc.
Its funny, I drove a friends S1 205GTI with the DFZ bottomend DKZ head setup with one of Peters stage 2 cams and it went very well indeed so I'm a bit antsy as to whether what I have coming is a bit of an overkill hahahaha. Time will tell.
I've parts arriving next week so i'll get some pictures up asap. Also for those of you that have been to my dyno days that hold, i'll probably be having another one at around easter (probably just after) to show off... hahaha.
Either ways, things are happening and look out you 16 valve 205s there is a fairly hot 8 valve coming.
:headbang:
:headbang:
