Phasis, you are welcome to make buttons, however the title bar is Javascript & I don't believe buttons would work with it, I may be wrong.
Unless I go the Frame method the forum doesn't like the fancy html.
Here is the script if anybody has a better idea for access to the main site with a single click:
<blockquote><font size="1" face="Verdana, Arial">code:<hr /><pre style="font-size:x-small; font-family: monospace;"><script language="JavaScript" src="navcond.js"></script>
<script language="JavaScript">
Top Navigational Bar II (By Mike Hall)
Last updated: 00/05/08
Permission granted and modified by Dynamicdrive.com to include script in archive
For this and 100's more DHTML scripts, visit http://dynamicdrive.com
var myNavBar1 = new NavBar(0);
var dhtmlMenu;
//define menu items (first parameter of NavBarMenu specifies main category width, second specifies sub category width in pixels)
//add more menus simply by adding more "blocks" of same code below
dhtmlMenu = new NavBarMenu(125, 0);
dhtmlMenu.addItem(new NavBarMenuItem("aussiefrogs home", "http://www.aussiefrogs.com/site.html"));
myNavBar1.addMenu(dhtmlMenu);
dhtmlMenu = new NavBarMenu(100, 120);
dhtmlMenu.addItem(new NavBarMenuItem("Concours", ""));
dhtmlMenu.addItem(new NavBarMenuItem("Past Events", "http://www.aussiefrogs.com/pe.html"));
dhtmlMenu.addItem(new NavBarMenuItem("Pictures", "http://www.aussiefrogs.com/pict.html"));
dhtmlMenu = new NavBarMenu(110, 170);
dhtmlMenu.addItem(new NavBarMenuItem("Club Info", ""));
dhtmlMenu.addItem(new NavBarMenuItem("Australian Club Register", "http://www.aussiefrogs.com/cr.html"));
dhtmlMenu.addItem(new NavBarMenuItem("Australian Club Links", "http://www.aussiefrogs.com/local.html"));
dhtmlMenu = new NavBarMenu(100, 150);
dhtmlMenu.addItem(new NavBarMenuItem("Road Tests", ""));
dhtmlMenu.addItem(new NavBarMenuItem("Citroen Road Tests", "http://www.aussiefrogs.com/drop.html#citroen"));
dhtmlMenu.addItem(new NavBarMenuItem("Peugeot Road Tests", "http://www.aussiefrogs.com/drop.html#peugeot"));
dhtmlMenu.addItem(new NavBarMenuItem("Renault Road Tests", "http://www.aussiefrogs.com/drop.html#renault"));
dhtmlMenu.addItem(new NavBarMenuItem("Frog Related Info", "http://www.aussiefrogs.com/drop.html#frog"));
dhtmlMenu.addItem(new NavBarMenuItem("Archive", "http://www.aussiefrogs.com/archive.html"));
dhtmlMenu.addItem(new NavBarMenuItem("Links", ""));
dhtmlMenu.addItem(new NavBarMenuItem("Froggy Links", "http://www.aussiefrogs.com/fl.html"));
dhtmlMenu.addItem(new NavBarMenuItem("Local Links", "http://www.aussiefrogs.com/local.html"));
dhtmlMenu.addItem(new NavBarMenuItem("Member Links", "http://www.aussiefrogs.com/member.html"));
dhtmlMenu.addItem(new NavBarMenuItem("Submitted Links", "http://www.aussiefrogs.com/snippets/links.htm"));
dhtmlMenu.addItem(new NavBarMenuItem("Members Gallery", "http://www.aussiefrogs.com/gallery/usergallery.htm"));
//set menu colors
myNavBar1.setColors("#000000", "#000000", "#8fbc8f", "#ffffff", "#3299cc", "#000000", "#cccccc", "#ffffff", "#000080")
//uncomment below line to center the menu (valid values are "left", "center", and "right"
//myNavBar1.setAlign("center")
var fullWidth;
function init() {
// Get width of window, need to account for scrollbar width in Netscape.
fullWidth = getWindowWidth()
- (isMinNS4 && getWindowHeight() < getPageHeight() ? 16 : 0);
myNavBar1.resize(fullWidth);
myNavBar1.create();
myNavBar1.setzIndex(2);
//UNCOMMENT BELOW LINE TO MOVE MENU DOWN 50 pixels
//myNavBar1.moveTo(0, 50);
</script> </pre><hr /></blockquote><font size="2" face="Verdana, Arial">Also, is everyone being redirected into here when going to <a href="http://www.aussiefrogs.com" target="_blank">www.aussiefrogs.com</a> ?
One of my customer's PC's today was not
cheers!
